Graphical error after update to 2013 SP3
8 REPLIES 8
Message 1 of 9
tony.ridley
484 Views, 8 Replies
Hi
This problem is similar to this one, but now worse;
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Filter-by-Selection/m-p/3334527#M2780
The problem is that now I've installed SP3, the windows 7 scheme turns to compatability mode after using "filter by selection".  The taskbar changes colour and also looses the "areo peek" function (where you can see the small picture when hovering over the probram icon).  The picture below is standard windows 7 aero peek taskbar.  I will send a video via PM to show what happens after Robot "filter by selection" is used.
Thanks, Tony
8 REPLIES 8
Message 2 of 9
Tony,
Could you check if there is the same situation when you work with one monitor only? Thank you.
Artur Kosakowski
Message 3 of 9
ok.  On Monday sorry
Message 4 of 9
Ievgen
in reply to: Artur.Kosakowski
The same problem using Concrete Building Structures 2013 (1 and 2 monitors)
Message 5 of 9
tony.ridley
in reply to: Ievgen
strange it only started after installing SP3
Message 6 of 9
Artur.Kosakowski
in reply to: Ievgen
Do you mean the switch to the compatibility mode of the too wide dialog?
Artur Kosakowski
Message 7 of 9
Ievgen
Nope. I guess it's in general. When the application starts, windows sets the basic theme which disables the aero (monitor blinks)
I have this problem on 2 PC: with nVidia Quadro 4000 and Radeon HD 7970, so I mean it doesn't depends which vendor is used
Message 8 of 9
Artur.Kosakowski
in reply to: Ievgen
This is entirely different issue that the situation on Tony's computer. CBS (even with no SP installed) switches display due to the fact that the buttons indicated below are not supported by Microsoft in the areo mode of Windows.
Artur Kosakowski
Message 9 of 9
Ievgen
Sorry. Then my complaint doesn't worth your attention. Thank you for your reply anyway.
