Discussion Groups
Robot Structural Analysis
Valued Contributor
5 Kudos
getting internal forces from RSA to XL (API)
728 Views, 16 Replies
10-09-2012 05:21 AM
Hello everybody,
I wonder if it is posible to get the internal forces from RSA to XL :
- with the possibility of choosing the dimensions ( N, daN, daN.N, etc)
- getting first the values for the origin of the bar for all the load cases and then the values for the end of the bar
- getting Fx as Fxcompression and Fxtraction
if someone could help me please!
Benoît
Product Support
1,305 Kudos
Re: getting internal forces from RSA to XL
10-09-2012 05:34 AM in reply to: TraitCarré
Make these settings in table then select whole table (CTRL+A) or some records then copy it to clipboard then paste it in Excel
or take a look at this thread and find there example macros (message 12, 14, 19, maybe 22):
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Export-results-ARSA-via-API/m-p/3294083/high...
Rafal Gaweda
Valued Contributor
5 Kudos
10-10-2012 02:19 AM in reply to: Rafal.Gaweda
OK thanks!
message 22 is (almost) what I was looking for.
benoît
Product Support
1,305 Kudos
10-10-2012 02:39 AM in reply to: TraitCarré
The file for message 22 attached.
What changes would you like to have?
Rafal Gaweda
Valued Contributor
5 Kudos
10-10-2012 04:01 AM in reply to: Rafal.Gaweda
Thanks for the file!
I would like to have Fx as traction and compression, if possible.
My final goal is to analyse those values in order to get the max bending moment and the max of FX and Fz resultant (squareroot(Fx²+Fz²)) for each point (node) on the bar.
I've you this kind of macro?
Product Support
1,305 Kudos
Re: getting internal forces from RSA to XL (API)
10-10-2012 07:34 AM in reply to: TraitCarré
Try this
Rafal Gaweda
Valued Contributor
5 Kudos
10-11-2012 11:37 PM in reply to: Rafal.Gaweda
OK thanks,
I will add some macro to get the maximum force for each bar extremity in order to design the connection.
I could use the SpreadsheetCalculator, but for the moment, we don't use the Eurocode5....
rgds
benoît
Product Support
1,305 Kudos
10-12-2012 12:42 AM in reply to: TraitCarré
I have also such macro
Rafal Gaweda
Valued Contributor
5 Kudos
10-12-2012 02:11 AM in reply to: Rafal.Gaweda
GREAT! :smileyhappy:
I will just add a column with sqr(Fx²+Fy²+Fz²) and that will be fine.
Many thanks
Benoît
Valued Contributor
5 Kudos
10-16-2012 04:34 AM in reply to: Rafal.Gaweda
After analyse, this macro is not exactly what I wanted.
I have a hall with several time the same frame.
I want to select the same bar of each frame (all the rafters for exemple), and find the bar which has the maximum Sqr(Fx²+Fz²) and the maximum My.
Would you have some macro like that?
rgds
Benoît
