I really need your help on this one, I've been removing the incoherence on the meshes for this model. I read from the forums that these are the causes for "cyclic error". It's very difficult when this error comes because analysis run just would'nt continue untill I find the solution.
For this case, I tried to align the walls where there are incoherence and then remesh. But after running analysis, I observed that the panel contour definition returned to misalignment. I used the object geometry macro to see this. I believe that should not happen, hence, I appear stuck since the solution I am working on just comes back every time I run analysis.
Attached is the picture of the set of walls im aligning together. Below also is the link to file.
http://www.4shared.com/zip/HbM6_wXY/Epicentre-Model_A_v33.html
Hoping for your help.
Rico
Solved by Rafal.Gaweda. Go to Solution.
Meshes corected in this file
- no kinematic links,
- no regular mesh
- arc shaped plate - arc should be create as desccrete arc to correcty match bars or as a series on lines
model: http://we.tl/XykBqDNVJQ
Thank you very much Rafal, I am currently running analysis. I saw in the model you sent that there are blue crosses on some nodes which I thought were the panel contour points, is this correct?
Also, since I wanted to see how to show them by myself, I tried to open display dialog box, but it won't open!? Could this be a bug?
I have changed arcs to polylines (I drew whole panel again)
Yes.
