Discussion Groups
Robot Structural Analysis
New Member
LievenC
Geometrical imperfection
242 Views, 3 Replies
01-17-2013 06:35 AM
Dear,
I want to take into account the geometrical imperfection of some bars. The problem is that the calculation does not come to convergence.
How can I solve this problem?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Geometrical imperfection
01-17-2013 06:50 AM in reply to: LievenC
My assumption is that you have non linear analysis. You may try to set the Full Newton-Raphson method (both update check boxes marked) but it is also possible that the applied load is excessive for the initially deformed structure (you may try to reduce it and check again).
Artur Kosakowski
New Member
LievenC
01-17-2013 07:31 AM in reply to: Artur.Kosakowski
Thanks, yes I have non linear analysis. Where can I set the Fill Newton-Raphson method on?
Product Support
Artur.Kosakowski
01-17-2013 07:45 AM in reply to: LievenC
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Non-linear-Static-Analysis-Parameters/m-p/36...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Nonlinear-analysis-Iteration/m-p/3385747
Artur Kosakowski
