Rafal/Artur,
How are you guys today?
I have a model with beams, columns and panels, and I generate the model using;
Analysis----->Analysis Types--------->Structure Model-------->Generation of Computation Model
Lets say I have deal load (1), super dead (2), and live load (3) cases. While I'm making sure the model works OK, I set the second 2 cases to auxilliary. After I'm happy with the model under dead load only, I want to add the other cases. I have node loads and planar loads in the 2nd and 3rd cases.
1st Question:
Do I need to regenerate the computational model before I run the 2nd and 3rd cases? Or if I calculate without generating the model, will it work OK??
2nd Question:
If I have run the first 3 cases (and done model generation) but then I want to add modal and spectral, do I need to regenerate the computation model?
Thanks as always,
Tony
Solved by Rafal.Gaweda. Go to Solution.
1st Question:
IN case of only nodal loads added - no need to generate model. Otherwise yes.
2nd Question:
Yes. Masses must be generated.
One more remark about combinations with aux case.
If the model is linear - combination combines results so if combination contains aux case you will not get results for such combination because there are no results in aux case
If the model is nonlinear or at least the combination with aux case is nonlinear - combination combines forces from all cases from its definition so after calculations you will get results.
2nd Question:
OK.
So if I run modal and don't get enough modes, or want to change the direction factor in spectral, or change the factor in load to mass conversion, do I need to regenerate the computation model?
Cheers,
Tony
Hi Tony,
Try Calculation Restart option.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
No.
I do not recomend such actions because in the meantime you can make changes in model and they will not be considered in calculation.
This can be helpful also:
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-8E0F5493-49E9-4363-B33D-5D8077A10C9-606.htm
Thanks Romanich, I have used this one before.
But it occured to me that if I had already unchecked the generate computation model that it might give an error.
No.
Sorry Rafal, to clarify, do you mean "no, you don't need to re-run the model generation" or "no, don't do it"?
Cheers,
Tony
No.
OK.......so the first time I define a modal analysis and assign load to mass conversion, the loads are converted to masses during the initial model generation. If I then modify the conversion factor, it is just scaled from the previous calculation? Sorry to keep asking the same question in a different way.
Exactly. You are right
The same with spectral direction factor.
