Bonjour,
Quand on fait la génération du vent en 3D, j'obtiens les charges de vent sur les lisses de bardages et les pannes, et les poteaux?
Comment faire?
I'm not sure if I understand you correctly but this option assumes that when you generate elements that are perpendicular to frames then climatic loads are applied to these elements instead to frames directly. If you want to have them applied to the frames you can generate roof beams and side beams after automatic generation of 3D model.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Hello Sir,
I don't understand your answer but that's what I want to know:
when I generated the wind in 3d and the wind is not applied on the frames, I have to restart the generation of wind with panals?
Is this what you want to obtain?
I have no problem with downloading and opening this docx file. Anybody else having such issue as well?
when I generate the wind in 3d, I need to create BARDAGES to redistribute wind loads?
I ask this question because the wind is not applied to all elements of the building!!!
Can you help me to understand the way to generate wind to all of elements
Thank you in advance
When you start from 2D frame and you generate 3D structure with automatic wind generation you have two options for applying wind loads:
1. You apply them to the frames directly (columns and rafters)
2. You apply them to purlins (bars perpendicular to the frames) instead
so I ca apply loads to all of elements!!
that's a problem because I need to calculate the other loads
i have two other questions:
1- Can I do the faces or BARDAGE to apply all loads of wind??
2- what about the combinations? I do them manually or automatically or both??
Thank you
I'm not sure if I understand your issue correctly. Generating wind load in automatic way you have the choice I mentioned (if you apply load to purlins then it will be transferred to main frames as if applied to claddings). For other loads (load cases) you can apply them to any element of a model.
Yes, you can define claddings and apply load to them but not as apart of the automatic wind generation tool we have been discussing in this topoc.
Either or.
