Hello you all.
Can anybody teach me how to see graphically the spectrum automatic generated by Seismic definition, per example Seismic EC8?
Best regards.
Solved by Artur.Kosakowski. Go to Solution.
It can be found in the calculation note (Analysis > Calculation Report).
Thanks Artur.
Can i acess it in editable way, viewing step by step values?
I'm not sure if I understand you correctly. Could you describe what would be needed in more detailed way please? Thank you.
By calculation report i see spectrum like an image. I'cant see step by step coordinates.
To find the values you need to use the descriptions of the axes and set of lines that are intended to make this task easier. There is no interactive diagram available.
