Generate EC wind loads by API
7 REPLIES 7
Message 1 of 8
884 Views, 7 Replies
I am trying to understand how to generate Eurocodes wind loads by API.
This how I proceed:
First I configure the project prefs
ProjectPrefs.SetActiveCode(IRobotCodeType.I_CT_SNOW_WIND_LOADS, "NF-EN 1991-1-3/4/NA:2007/2008")
Then I generate the loads
        Dim SWCodeParams As RobotSWCodeECParams
        Dim SWCombEngine As RobotSnowWindEngine
        SWCombEngine = str.Cases.SnowWindEngine
        SWCodeParams = SWCombEngine.CodeParams
        SWCodeParams.StructureAge = 2
        SWCombEngine.Params.TotalDepth = 15
        SWCombEngine.Params.BaySpacing = 5
        SWCombEngine.Generate()
I don't see how to configure SWCombEngine with SWCodeParams.
Your help would be very appreciated. Thanks in advance.
Francois
7 REPLIES 7
Message 2 of 8
Rafal.Gaweda
Code names are listed in this file:
"c:\Users\All Users\Autodesk\Structural\Common Data\2013\Data\Other\norms.xls"
so correct line should be like that:
ProjectPrefs.SetActiveCode(IRobotCodeType.I_CT_SNOW_WIND_LOADS, "EC1 - French NAD")
Rafal Gaweda
Message 3 of 8
Ok for that but it does not change anything.
I would like to change programmatically the parameters of eurocodes wind and snow loads genereation.
If I do
        SWCombEngine.CodeParams.WindCd = 1.5
        MsgBox("WindCd " + SWCombEngine.CodeParams.WindCd.ToString)
WindCd value still remains unchanged to 1.
Maybe this cannot be done by API.
Francois
Message 4 of 8
Rafal.Gaweda
Unfortunately you are right. Due to bug in API you can not set Params, Codeparams for SW generator.
You can only get them. I will register it for correction.
Rafal Gaweda
Message 5 of 8
in reply to: Rafal.Gaweda
Great, I was struggling since 2 days on it to find a solution. Do you think it can be implemented in the next update of Robot?
Again thanks for your help, I think I will have more questions in the future.
Francois
Message 6 of 8
Rafal.Gaweda
workaround : RobApp.Project.Structure.Cases.SnowWindEngine.ShowParamsDlg()
then enter these values manually in the window
Rafal Gaweda
Message 7 of 8
I've just started working with API Robot and I've been blocked in this part. I use the Autodesk Robot 14. By these codes I can only change the parameters such as "Depth of Structure" and "Bay Spacing" but I can't change the code parameters (Eurocode 1 in my case) such as "Structure Age", "Altitude" etc. You've answered in last posts that there is a bug which prevent this processus. I would like to know if this problem and this bug has been resolved in Autodesk Robot 14 or 15?
Thank you in advance for your answer
Goodarz
Message 8 of 8
xblanchet
in reply to: goodarz.shafiei
After 7 years, has the problem been solved ?
I have the same problem with my script.
regards,
