Hi, I am dealing with a problem of modeling a masonry wall with FRP stripes as a strenghtening. I can not find any tutorial or tips about frp stripes modeling in Robot. Is it even possible to model frp wall strenghtening in Robot.. I found some info about ansys e.g. but not Robot..
If anyone has some experiance or acces to materials which would help me, please share.
I suppose that you should also modify the properties of the material that is used for these walls (modified as concerns the updated parameters due to the strengthening)...
Maybe it would be helpful if you take a look at an older post related to masonry walls: http://forums.autodesk.com/t5/Robot-Structural-Analysis/Mansory-muti-story/td-p/4456463
