You tell me all the settings to do in order to run the combinations according to the Eurocode, but in France?
The snow load and wind 2D/3D you can activate it again in accordance with the above?
Robot is now set parameters Italian.
thanks
Solved by Rafal.Gaweda. Go to Solution.
Regarding seismic loads the norm is the exact urocodice 1998-1/NA NF EN 2007 19 juil 2011 and not the PS92?
thanks
IN the first post you asked about code combinations and snow&wind, not seismic.
Set seimic code according to your needs.
why snow and wind loads must be taken according old code (NV65 and N84) for 3D structure type?
rgds
Benoît
