Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
frame generator extension
7 REPLIES 7
Message 1 of 8
884 Views, 7 Replies
When using  frame generator and selecting geometry the screen freezes and I have to restart the program. this only happens when selecting geometry with the rest of options ( Bays, project, ......) I have no problems.
What should I do? Thanks
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
Could you make a move that shows this situation or describe steps to follow please?
Artur Kosakowski
Message 3 of 8
in reply to: Artur.Kosakowski
When selecting geometry screen locks, I can not complete the dimensions of the structure, the  frame generator is no longer responding.
With the rest ( Bays, Project, Truss, Deck Slabs......) I do not have that problem.
Message 4 of 8
Artur.Kosakowski
I can't see any issue in Robot 2015 SP3
What is your version of Robot?
Artur Kosakowski
Message 5 of 8
I have the 2014 version. In my screen, the yellow and green frame do not appear in geometry. Should I reinstall the software?
Message 6 of 8
Artur.Kosakowski
I can't see any issue either. Do you have SP5 installed?
Artur Kosakowski
Message 7 of 8
yes, I´ve SP5 installed
Message 8 of 8
Artur.Kosakowski
Try to replace the files from c:\Program Files\Common Files\Autodesk Shared\Extensions 2014\Modules\Modeling\DLTFrame3D\Configuration\Defaults folder with the attached ones.
Artur Kosakowski
