When using frame generator and selecting geometry the screen freezes and I have to restart the program. this only happens when selecting geometry with the rest of options ( Bays, project, ......) I have no problems.
What should I do? Thanks
Solved by Artur.Kosakowski. Go to Solution.
Could you make a move that shows this situation or describe steps to follow please?
When selecting geometry screen locks, I can not complete the dimensions of the structure, the frame generator is no longer responding.
With the rest ( Bays, Project, Truss, Deck Slabs......) I do not have that problem.
I can't see any issue in Robot 2015 SP3
What is your version of Robot?
I have the 2014 version. In my screen, the yellow and green frame do not appear in geometry. Should I reinstall the software?
I can't see any issue either. Do you have SP5 installed?
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Try to replace the files from c:\Program Files\Common Files\Autodesk Shared\Extensions 2014\Modules\Modeling\DLTFrame3D\Configuration\Defaults folder with the attached ones.
