Hello All,
After a calculation with EC7 regulations, I have a few comments on the results.
In the attached pdf highlighted pointsconcern:
- calculating (page 😎 of B 'and L'
- warning about the instability that I do not understand
Solved by Simau. Go to Solution.
Attach the rtd file with this example please.
I think this is triggered by the fact that the following condition has not been fulfilled
please find attached rtd file and a new pdf file with ratios highlited in green. All ratio seems ok, so don't understand warnig about instability.
This is exactly the situation I suggested (see the attached picture) . You can either uncheck A and B and allow Robot to fine the correct dimensions of the foundation or ignore/switch off this verification.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
As far as I can see there are two issues which we have to address:
1. These values should not be displayed at all for the semi-empirical method.
2. For other methods they are replaced
