Hello All,
After a calculation with EC7 regulations, I have a few comments on the results.
In the attached pdf highlighted pointsconcern:
- calculating (page 8) of B 'and L'
- warning about the instability that I do not understand
M. Agayr
Solved by Simau. Go to Solution.
Attach the rtd file with this example please.
I think this is triggered by the fact that the following condition has not been fulfilled
please find attached rtd file and a new pdf file with ratios highlited in green. All ratio seems ok, so don't understand warnig about instability.
M. Agayr
This is exactly the situation I suggested (see the attached picture) . You can either uncheck A and B and allow Robot to fine the correct dimensions of the foundation or ignore/switch off this verification.
As far as I can see there are two issues which we have to address:
1. These values should not be displayed at all for the semi-empirical method.
2. For other methods they are replaced
Thanks for help
M. Agayr
