Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Foundations and EC7
5 REPLIES 5
Simau
526 Views, 5 Replies
Foundations and EC7
Hello All,
After a calculation with EC7 regulations, I have a few comments on the results.
In the attached pdf  highlighted pointsconcern:
- calculating (page 😎 of B 'and L'
- warning about the instability that I do not understand
5 REPLIES 5
Artur.Kosakowski
in reply to: Simau
Attach the rtd file with this example please.
I think this is triggered by the fact that the following condition has not been fulfilled
Artur Kosakowski
Simau
in reply to: Artur.Kosakowski
please find attached rtd file and a new pdf file with ratios highlited in green. All ratio seems ok, so don't understand warnig about instability.
Artur.Kosakowski
in reply to: Simau
This is exactly the situation I suggested (see the attached picture) . You can either uncheck A and B and allow Robot to fine the correct dimensions of the foundation or ignore/switch off this verification.
Artur Kosakowski
Artur.Kosakowski
in reply to: Simau
As far as I can see there are two issues which we have to address:
1. These values should not be displayed at all for the semi-empirical method.
2. For other methods they are replaced
Artur Kosakowski
Simau
Thanks for help
