Discussion Groups
Robot Structural Analysis
Valued Contributor
oyvinkle
Foundation
183 Views, 3 Replies
01-28-2013 09:42 AM
Hey!.
When i cross the box for UX,UY, UZ, RX, RY and RZ i know that the spring stiffnes is not infinity but have a value. What are there values. this is for Node boundry contitions and linear boudrty conditions..
Please use plain text.
Product Support
Artur.Kosakowski
Re: Foundation
01-29-2013 12:20 AM in reply to: oyvinkle
To define an elastic support you should type values of elasticity rather than mark the given check box as shown below:
Artur Kosakowski
Valued Contributor
oyvinkle
Re: Foundation
01-29-2013 04:09 AM in reply to: Artur.Kosakowski
Thanks! But I was thinking of the defult value that robot has built inn :smileyhappy:
Product Support
Artur.Kosakowski
Re: Foundation
01-29-2013 04:12 AM in reply to: oyvinkle
There's no default value but you can use estimate it using the tool described here:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Elastic-ground-bar-definition/td-p/3760644
Artur Kosakowski
