I 've modeled a steel frame structure and i want to add continuous footing foundation to it.
How is this possible? Is there a way to create it and appear on my model? And as for the loads, is there a way to get the loads from the building automatically or should i do it manually?
Solved by Rafal.Gaweda. Go to Solution.
You can also check here http://www.robotoffice.com/rsa/
there are 2 videos for spread footing and continuous footing
Yeah, found an older post of Rafal aswell with this link http://screencast.com/t/oqzjXKKhND
