i'm working on the foundation, but can't find the calculation option set window. can you please tell me where to find it?
Solved by Artur.Kosakowski. Go to Solution.
i tried using a square one , but i still dont get the numbers. what to do?
1. Switch layout to the one where you can see the model
2. Check what values of reactions you have in the node you want to design the foundation for
3. Select the node and export it to the RC Foundation module (make sure you import combinations)
4. Check the loads
If they are as the reactions then in is ok, otherwise send me the model and indicate the node number.
when i look at the node proprties, all the values are there. can I write in the values manually?
They should be imported from the model. Try to open the load table in the RC Foundation module after you imported the loads from the model using RC Element > Load table. Can you see the imported loads correctly?
