Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Forces in nodes
16 REPLIES 16
Message 1 of 17
1743 Views, 16 Replies
Forces in nodes
Hi!
Where can I find how much force (in the x-axel) each highlited node is exposed to?
Best regards,
Lina
16 REPLIES 16
Message 2 of 17
Mohammed_Ata
Results >> forces .
see the attachment . is it ok ?
Message 3 of 17
in reply to: Mohammed_Ata
That's what I thought, but I can't choose "Forces" for this type of structure.. what can I do about it?
Message 4 of 17
Mohammed_Ata
From your attachment , it seems that you defined only walls and floors which are be described as pannels .
to get forces on them ... Results >> plate  and shell results
Message 5 of 17
dimogrec
"Forces" results are refered to bar elements. The same goes for "Deflections" and "Stresses". As Mohammed wrote it seems you have no bar elements in your model.
Tags (2)
Message 6 of 17
in reply to: dimogrec
Does this mean that I can't get the force for one wall in my model?
Message 7 of 17
dimogrec
There are different options for that
results-> diagram for buildings -> core walls (presupposed that first you need to tansform a wall to a core)
results-> core walls (table)
results -> maps  then check membrane forcesN or M, or Q
results -> Plate and shell results (table)
Also the results in "story table" have infos about walls
Message 8 of 17
Hi again..
I've found the force in each wall after transforming them into core walls, then I've got the result in the table "Definition and results for core walls". It's here shown different results,
Core Wall/Story/Cut/Case
What I understand Cut shows two values for one wall in one story, (Cut 1 and Cut 2) on the lower edge and on the upper edge. Is this correct?
My question is, how can I get the result on just one Cut?
Not sure if this is explained enough, let me know!
/Lina
Message 9 of 17
Rafal.Gaweda
 Not possible.
Copy table to Excel and delete records for Cut 1 or 2
Rafal Gaweda
Message 10 of 17
Simau
in reply to: Rafal.Gaweda
 Hi
iI continue this thread because i have a substructure to study..
Is it possible to extract the efforts in the highlighted nodes from the global model, in order to use them as simple cases.
Message 11 of 17
Simau
in reply to: Simau
Just a precision,
when these nodes are in foundation, it is posible to get the efforts via the reactions, as explained here
http://forums.autodesk.com/t5/robot-structural-analysis-forum/substructure-and-load-case/td-p/640251...
My question concerns the nodes of the upper levels of a building.
Message 13 of 17
Simau
Ok Rafal,
I remember this thread.
It was very usefull to get forces from nodes with frame structure.
With nodes in pannels, it doesn't work.
It's difficult to modify Finite Element model by introducing riigd links at the place we need information.
So, is there a mean to get directly efforts on hilighted nodes?
If exists, this method will be great.
Message 14 of 17
Simau
in reply to: Simau
I come again about this topic.
If we need efforts on the lower nodes of  a panel, how do we proceed?
Its possible for nodes on bars, but not on nodes panels.
Message 15 of 17
Artur.Kosakowski
in reply to: Simau
Artur Kosakowski
Message 16 of 17
Simau
in reply to: Artur.Kosakowski
Thanks Artur
Please step by step how you get this table
Message 17 of 17
Artur.Kosakowski
in reply to: Simau
Here you are:
Artur Kosakowski
