I am after the envelope/global extreme forces filtered for specific nodes.
The forces table provides two set of values per bar (1 at each end) and can only be filtered by bars.
Is there a solution?
Solved by Rafal.Gaweda. Go to Solution.
Solutions :
1.
2. Macros : different macros for different purposes
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Local-reactions-API/td-p/3791474/page/2
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-for-max-moment/td-p/4762433
