Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
scarpignatof
329 Views, 1 Reply
Footfall analysis
I am having trouble obtaining results from a footfall analysis. It also doesn't seem to run a modal analysis either.
I have a single floor plate with offset beams spanning onto pinned nodal supports, with two linear supports on the edges (beam file attached).
I've also tried modelling the floor plate with panels as beams to see if this makes a difference but again no results are obtained (slab file attached).
1 REPLY 1
I can't see any issue.
You may try to install SP2 for Robot 2015
Artur Kosakowski
