I am having trouble obtaining results from a footfall analysis. It also doesn't seem to run a modal analysis either.
I have a single floor plate with offset beams spanning onto pinned nodal supports, with two linear supports on the edges (beam file attached).
I've also tried modelling the floor plate with panels as beams to see if this makes a difference but again no results are obtained (slab file attached).
I can't see any issue.
You may try to install SP2 for Robot 2015.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
