Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Footfall Analysis - AISC DG11 vs Concrete Centre
1 REPLY 1
641 Views, 1 Reply
I have performed footfall anaylsis on a number of buildings, and in almost all cases the buildings fail the criteria for the Concrete Centre (Rf<8) when that analysis is run, but when the AISC DG11 analysis is run the buildings pass with flying colours (max a < 50mm/s/s).
Further, I'm getting some funny discrepencies in the results, each giving different problem areas. For example:
Concrete Centre Method:
AISC DG11 Method
Ultimately I am designing the building for AISC DG11 criteria, but was just wanting to know if the Concrete Centre calculation method is more accurate, and if it is normal to have such large differences between the analysis methods?
I've attached some screenshots of my results, and a link to my model is here:
http://www.filemail.com/t/b54a1a705ae94710914e47f1ed81a9da
Daniel
1 REPLY 1
mustafahesenow
Hi @Anonymous
I had checked the footfall analysis according to Aisc Design guide 11 manually and using Robot and both giving closed results .
I am not familiar with concrete cente.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
