I have performed footfall anaylsis on a number of buildings, and in almost all cases the buildings fail the criteria for the Concrete Centre (Rf<8) when that analysis is run, but when the AISC DG11 analysis is run the buildings pass with flying colours (max a < 50mm/s/s).
Further, I'm getting some funny discrepencies in the results, each giving different problem areas. For example:
Concrete Centre Method:
AISC DG11 Method
Ultimately I am designing the building for AISC DG11 criteria, but was just wanting to know if the Concrete Centre calculation method is more accurate, and if it is normal to have such large differences between the analysis methods?
I've attached some screenshots of my results, and a link to my model is here:
http://www.filemail.com/t/b54a1a705ae94710914e47f1ed81a9da
Daniel
