Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Fondation Beam
4 REPLIES 4
mjoflor
403 Views, 4 Replies
Fondation Beam
Hi , wheni modelling a fundation beam, it is necessary keep the support  in the columns or had to delete it????
4 REPLIES 4
Artur.Kosakowski
in reply to: mjoflor
I'm not sure if I understand you correctly. If you think about a model then you should remove vertical supports at bottoms of columns if they 'stand' on the ground beam (elastic soil applied). For the RC design module the difference will be in the arrangement of stirrups as shown on the attached picture.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
mjoflor
in reply to: Artur.Kosakowski
ok but if i delete the supports and let only de foundation beam with the elastic soil applied ,and made a verificacion appears a warning "no support" ????????
Artur.Kosakowski
Indeed as the elastic soil definition is not a support type object the verification gives such message however knowing that you have supported a model correctly (mind the horizontal direction as well) you can ignore it.
Artur Kosakowski
mjoflor
Ok thanks for your help
