Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Floor Thickness Transfer Error
5 REPLIES 5
SerhanB
275 Views, 5 Replies
In my Revit model I've defined a new floor section which has 50cm thickness. I've assigned this section to the floors which were previously 40cm in thickness. Send the model to robot and find out that that floors passed as 500cm! I've tried in different computers with same outcome. Can you please validate the error, I'm sending the model files with the link below.
section name D500-B60
floors in revit (191421,201323,735187,741787,747494)
floors in robot ( 104 107 7115 7651 7652 )
http://share.stand.com.tr/public/4d65f8.php
Thanks for your helps.
Serhan BAKIR
http://www.stand.com.tr/
5 REPLIES 5
Rafal.Gaweda
in reply to: SerhanB
My file here : http://we.tl/5RhOqJGlFE
Rafal Gaweda
SerhanB
Hi Rafal,
Smiley Surprised how could this happen I really don't understand, never experienced such an error before.. And it makes me even more confused that on your side transfer is without errors. do you have any idea what can cause such a behaviour??
Serhan BAKIR
Leader_Mohamed
No it has nothing to do with sections or the way how sections are matched
Rafal Gaweda
SerhanB
I think Leader_Mohamed may have a point !
previously I've created a simple robot model and defined a section with the same name for a trial run (than erased that model). and it was a completely separate file from the original model that I have the current issue.
I guess, somehow, that section name with its erroneous properties, carried on to the original model which was transfered from revit. Does robot have a database file of sections seperate from the model file stored somewhere else?
Serhan BAKIR
