Is it possible to design flexible end plate connections (shear and tension for beam to column and beam to beam) using Robot? End plates are one of the most common connections in the UK and I find it very surprising that they are missing from a comprehensive design package as Robot.
I'm not sure if I understand you correctly. Do you mean that you would like to have the option to create from the model the already existing beam to column with end plate connection type in a situation where there is a release defined at the end of the beam (at the point it connects with a column)?
Artur what andrew is saying is that he would like to have this type ofconnection in Robot.
One of the three is available. For the other two could you indicate the reference for checking the capacity of the column's or main beam's webs against tension force in the secondary beam? Thank you.
Artur wrote One of the three is available
yes it works, using the "frame knee" connection type and adding manualy only shear force, although the result text is a little bit poor...
A very good reference for simple connections is the green book from sci
http://www.steelconstruction.info/index.php?title=Special:ImagePage&t=SCI+P358.pdf&internal_link=1
Artur,
Thanks for your reply. I tried the knee connection but it is meant for the moment loads. If you just use shear and tension the system will check each bolt row for bending and tension anyway. It would look incompetent to me if I sent a calcs like that to a client. I use the green book and BS 5950 for designing all the connections. I have got spreadsheets and other software to do it but my point is that when you pay serious amount of money for Robot you should not need to do such a simple calculations yourself. Flexible end plates are in my opinion one of the most common pinned connections in the UK (if not the most). I am very disappointed that Autodesk did not include that in the new 2015 version.
Cheers,
Andrew,
As you know BS is currently not supported in the connection module. Based on your suggestion I'd like to add this connection type to the wish list for the next versions of Robot but prior to doing so I'd like to find out the reference for checking tension force resistance based on EC3 provisions (the code that is supported in the steel connection module of Robot). My main point of interest is the check of the main element web capacity. Is this covered in the green book?
Thank you.
Any update on this since? poor that such a standard detail is ignored. green book for you;
http://www.steelconstruction.info/File:SCI_P358.pdf?internal_link
