Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Fire protection - steel design
4 REPLIES 4
pevelor
1125 Views, 4 Replies
Hi
I am wondering if someone could illustrate how to calculate necessary thickness of a given material for fire design.
Also, I am curios to know what the following means;
Thanks in advance
Peder
Tags (1)
4 REPLIES 4
Artur.Kosakowski
in reply to: pevelor
You make the assumption and run verification against defined fire type combinations. If the ratio is above 1 then you increase the thickness of the protection and check again.
7 is the number of  the bar from a model.
Artur Kosakowski
mpcloob
in the name of  GOD .
1) how can I see this form ( your image ) in my Design procedure ?
2) how can I investigate Fire Resistance in my Project ?
3) Is it possible to control for structue whole fire resistance?
thanks beforehand for your answers Smiley Wink
mpcloob
in reply to: mpcloob
Artur please answer my questions in previous post
Artur.Kosakowski
See the attached picture. Mind that the option is available for EC3 based steel design codes.
Artur Kosakowski
