Hi
I am wondering if someone could illustrate how to calculate necessary thickness of a given material for fire design.
Also, I am curios to know what the following means;
Thanks in advance
Peder
Solved by Artur.Kosakowski. Go to Solution.
You make the assumption and run verification against defined fire type combinations. If the ratio is above 1 then you increase the thickness of the protection and check again.
7 is the number of the bar from a model.
in the name of GOD .
1) how can I see this form ( your image ) in my Design procedure ?
2) how can I investigate Fire Resistance in my Project ?
3) Is it possible to control for structue whole fire resistance?
thanks beforehand for your answers
See the attached picture. Mind that the option is available for EC3 based steel design codes.
