Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Finite element mesh size
5 REPLIES 5
spspro
2878 Views, 5 Replies
Hello, any advice about mesh size calculating the RC panel. I tried mesh size from 0,2m to 1m and I got quite difference results, and if mesh size is small- 0,2m, I get a big amount of reinforcement, but only in a very small area (0,2x0,2m).
What is the optimal size of mesh calculating RS panels? Thanks
5 REPLIES 5
tony.ridley
in reply to: spspro
Fine mesh is more accurate but takes longer to calculate.
You need to find a good balance between speed and accuracy.
igos
in reply to: spspro
Hello, I'm using following rules for the RC slabs:
a = min(2h;(1/10)*l), where
a - element size;
h - thickness of the slab;
l - span of the slab.
Also, after meshing you have to estimate mesh quality (check for triangles with acute angle and for elementswith quite small ratio = a1/a2, where a1 - the smaller dimension of element, a2 - the bigger dimension of element)
_________________________________________
https://ru.linkedin.com/in/igor-saltykov-8a68b726
spspro
in reply to: igos
thanks igos
igos
in reply to: spspro
spspro,
You are welcome, also I can recommend you this quite useful guide: http://www.2shared.com/file/0GSMZ7D8/How-to-Design-rc-Flat-Slabs-Us.html
joseph.a.abouzeid
in reply to: igos
Hi egos, would you mind telling me how did you get this formula?
