Hi all.
I to try find Avaiable DOFs same v2000 of Robot, But I don't find Avaiable DOFs. Can you help me?. Thax
The easiest is to open the support definition dialog and check number of 'fields' for selected model type
hello Artu,can you help me of deformation truss verry max ?? Please picture.
I is attachment file.
You should check the section properties and make sure you entered the correct values.
Thank Artu.
I is math is are, Not section. File truss are A1=12cm2, A2=10cm2, A3=8cm2.
I want App are A1,A2,A3 to Robot. But I don't kown. Please ...... Thax.
Type these values in the Ax field.
