Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Final Drawings
5 REPLIES 5
eusmor
387 Views, 5 Replies
Final Drawings
How can I make final drawings for an option in the list of possible solutions, please see the screencast
http://screencast.com/t/g817XtJn
I want final drawings for the first option (2946.52 KG) but I find out for 3060 KG, (is not in my list)
PS the file is here
https://www.dropbox.com/s/qnda372d1v71df5/2277%20dalle%2Bstructure%20for%20final%20drawings.rtd?dl=0
5 REPLIES 5
eusmor
in reply to: eusmor
The link with screencast in the last message doesn’t work well, here are a new one
http://screencast.com/t/QJtxygpKfD
eusmor
in reply to: eusmor
Hi
Have you had time to see my files ?
Artur.Kosakowski
in reply to: eusmor
The prior value is based on the size of zones and theoretically calculated rebar weight (bar diameter and spacings in zones). The latter is based on finally generated rebars including anchorage lengths (which extend 'outside' the zones)
Artur Kosakowski
eusmor
in reply to: Artur.Kosakowski
Yes, now it’s clear for the difference between 2946.52 KG (first option in the possible solutions) and 3060 KG (final drawings)
But, if I want chose another option from the list of possible solution, for example (10 = 3387 KG) the final drawings remains the same. Then how can I get final drawings for this solution?
Artur.Kosakowski
in reply to: eusmor
https://screencast.autodesk.com/Main/Details/e3b18a52-acb2-44ff-8fec-133ba3010302
Artur Kosakowski
