How can I make final drawings for an option in the list of possible solutions, please see the screencast
http://screencast.com/t/g817XtJn
I want final drawings for the first option (2946.52 KG) but I find out for 3060 KG, (is not in my list)
PS the file is here
https://www.dropbox.com/s/qnda372d1v71df5/2277%20dalle%2Bstructure%20for%20final%20drawings.rtd?dl=0
Solved by Artur.Kosakowski. Go to Solution.
The link with screencast in the last message doesn’t work well, here are a new one
http://screencast.com/t/QJtxygpKfD
The prior value is based on the size of zones and theoretically calculated rebar weight (bar diameter and spacings in zones). The latter is based on finally generated rebars including anchorage lengths (which extend 'outside' the zones)
Yes, now it’s clear for the difference between 2946.52 KG (first option in the possible solutions) and 3060 KG (final drawings)
But, if I want chose another option from the list of possible solution, for example (10 = 3387 KG) the final drawings remains the same. Then how can I get final drawings for this solution?
https://screencast.autodesk.com/Main/Details/e3b18a52-acb2-44ff-8fec-133ba3010302
