Hi all
Who knows how to purge big .rtd files without affecting the basic data, like: nodes, elements (bars/panels)
Saving without results, left the file at 50% of its original size, but it is not enough
it contains too much unusable data like old drawings
This affect the performance, because it takes too long perform any order that involves load, transfer
Thanks in advance
You can try opening the file with "Repair Mode" active:
To avoid unexpected effects please folllow the steps described in the message 6 of this post:
Opening in Repair Mode does not remove screen captures from Printout Composition so it may be useful to open it and delete unnecessary screen captures.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Thank you Pawel
Opening the file in repair mode it is ok.
Using the label manager and deleting the unused element definition
Design ... Steel Member Design Options.... Code Parameters
Label manager ( in order to delete my renumbered elements Member Definition Parameters)
it deletes all the unused definitions, inclusive the material definition for existing elements
this makes the file unusable
Are you sure that used labels were deleted?
When deleting unused labels is run while several dialogs with labels are opened it is possible to observe some effects resulting from not refreshing the dialogs - like in this video
But as you can see in it the labels are not deleted - after re-opening the dialog all used labels are displayed.
