Rafacascudo
488 Views, 6 Replies
File doesn´t open
     I´ve started a model "A" on a win 7 32bit computer.Brought it home , completed this model on a win7 64 bit computer.
Then, from this model "A" I created a model "B"  with 40 phases (different support positions,pushed bridge), which I completed sucessfully. Then , I brought the model back the 2 models to the 32bit computer(what i have done with other models sucessfully for several times in the past).   It happens now that model A opens normally while model B opens like in the screenshot atached.Title bar says it´s opened ,but main screen doesn´t show the model.Tried emptying the cfgusr folder, running it again through the manager(doesn´t work) , but it stays the same.Opening it in repair mode ,works but I loose all the phases , which was a 3 hour work And I want to avoid doing it over again.
Any ideas?
model file here,  http://www.sendspace.com/file/crf9q2
Rafael Medeiros
6 REPLIES 6
Rafal.Gaweda
in reply to: Rafacascudo
I have downloaded this model and opened it in 2013 SP2 64 bit version without any problems.
http://www.4shared.com/zip/b7gaBsMa/Ponte_Ptio_de_estocagem_-_fase.html
Rafal Gaweda
Rafal.Gaweda
in reply to: Rafal.Gaweda
Also on 32 bit was OK:
http://www.4shared.com/zip/GQqzSu8K/Ponte_Ptio_de_estocagem_-_fase.html
Rafal Gaweda
Rafal.Gaweda
Try: Tools \ Customize \ Open layouts from template or Window \ Add View \ View if you see text menu
PS.
Open the file by File \ Open rather than making double click on it or draging it onto robot window.
Rafal Gaweda
Rafacascudo
Open layouts from template does nothing
Window/Add view/view or table crashes the program
64 bit file you sent behaves the same way
32 bit file opens normally!!!!
thanks,
Rafael Medeiros
Rafacascudo
well, your file opened ,but less than half of the phases were there ,and running the file gave " isolated nodes , and instability warnings.
thank you anyway!!
Rafael Medeiros
Rafal.Gaweda
So use 64 bit Robot to continue work with this model.
Rafal Gaweda
