Discussion Groups
Robot Structural Analysis
New Member
mohamedx61
Ferraillage d'une poutre courbé?
305 Views, 3 Replies
01-15-2013 09:27 AM
Bonsoir a tous. je voudrai savoir pour le ferraillage d'une poutre courbé comme le montre la figure en dessous:
es-que RobotSA peut la ferrailler ou pas et comme le faire dans le cas ou il ne peut pas? Merci
Please use plain text.
Product Support
Artur.Kosakowski
Re: Ferraillage d'une poutre courbé?
01-16-2013 12:02 AM in reply to: mohamedx61
For bent beams you should use the RC Members Required Reinforcement module. Such beams are currently not supported in the RC Beam Reinforcement module.
Artur Kosakowski
Active Contributor
judicaeltapsoba
11-21-2013 12:18 PM in reply to: Artur.Kosakowski
mais pourquoi nous n'avons pas se probleme losque nous exportons une poutre courbe a partir de cbs?
Product Support
Artur.Kosakowski
11-22-2013 02:13 AM in reply to: judicaeltapsoba
I think we are discussing two different situations:
- definition of  a curved beam in a model of a structure which can be done as chain of small straight elements forming a arch
- calculations of provided reinforcement in the RCA Beam design module which is currently not supported in Robot
Artur Kosakowski
