Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
ferraillage d'une dalle
6 REPLIES 6
M.maazi
1637 Views, 6 Replies
Bonjour , J'ai voulu modéliser une dalle de forme circulaire, en béton armé, le calcul de ferraillage est bloqué par un message me disant que le calcul théorique n'est pas fait bien que j'ai passé par cette étape; à part l'obtention d'une cartographie illogique: l'echelle varie de (-87500) à (-100000cm2/cm) Voir captures.
6 REPLIES 6
M.maazi
in reply to: M.maazi
M.maazi
Artur.Kosakowski
As far as I can see the value of required reinforcement area in each of surface element is 0. Please check if by accident you created support in every node of the structure (e.g. applying a planar support to the panel)  having minimal reinforcement switched off in the reinforcement type assigned to the panel. Otherwise I will need the rtd file to check the model.
Artur Kosakowski
M.maazi
in reply to: Artur.Kosakowski
the file
Artur.Kosakowski
I'm not saing that I can read in somebody's mind but ... Smiley Happy
Artur Kosakowski
M.maazi
Smiley Happy
