Discussion Groups
Robot Structural Analysis
M.maazi
ferraillage d'une dalle
681 Views, 6 Replies
12-07-2011 06:57 AM
Bonjour , J'ai voulu modéliser une dalle de forme circulaire, en béton armé, le calcul de ferraillage est bloqué par un message me disant que le calcul théorique n'est pas fait bien que j'ai passé par cette étape; à part l'obtention d'une cartographie illogique: l'echelle varie de (-87500) à (-100000cm2/cm) Voir captures.
Please use plain text.
M.maazi
Re: ferraillage d'une dalle
12-07-2011 06:59 AM in reply to: M.maazi
M.maazi
12-07-2011 07:01 AM in reply to: M.maazi
Product Support
Artur.Kosakowski
12-07-2011 08:31 AM in reply to: M.maazi
As far as I can see the value of required reinforcement area in each of surface element is 0. Please check if by accident you created support in every node of the structure (e.g. applying a planar support to the panel)  having minimal reinforcement switched off in the reinforcement type assigned to the panel. Otherwise I will need the rtd file to check the model.
Artur Kosakowski
M.maazi
12-07-2011 08:46 AM in reply to: Artur.Kosakowski
Product Support
Artur.Kosakowski
12-07-2011 09:11 AM in reply to: M.maazi
I'm not saing that I can read in somebody's mind but ... :smileyhappy:
Artur Kosakowski
M.maazi
12-07-2011 11:34 PM in reply to: M.maazi
:smileyhappy:
