Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
458 Views, 5 Replies
FE local system
how to solve the problem we usualy have when the local system of fe elements does not equal the local system of panels?
It's something that happens all the time, and its a dangerous situation when we need to have loads according to local system, like soil or water.
I've tried  to redo the mesh (localy), to delete and create the panel with problems, but nothing seems to work.
Is there a trick to it?
Also, I heve this model that apears to be ok, in terms of fe local system, but then the displacements for the gravity load apear with the oposit signal. (see doc file)
Thank you in advance
Tags (3)
5 REPLIES 5
Artur.Kosakowski
Attach this model please.
Artur Kosakowski
in reply to: Artur.Kosakowski
I need to send by wetransfer, because the file is too big.
Is there an email to send it?
Ana Sofia Casanova
logo MelhoresEmpresasTrabalhar_1
R. Poeta Bocage, 13 B - 1600-581 Lisboa
Tel. 217520320/Fax 217520321
www.tetraplano.com
Rafal.Gaweda
in reply to: Rafal.Gaweda
Here it is.
http://we.tl/nb81SI9loa
Tetraplano
Artur.Kosakowski
When you open this file (or any other with  the similar issue) in Robot 2014 the orientation of surface elements will be automatically set as the orientation of the corresponding panels.
Artur Kosakowski
