Discussion Groups
Robot Structural Analysis
Distinguished Contributor
refaat
factor of safety for shear in RC-Columns
259 Views, 4 Replies
12-24-2012 11:48 PM
Dear Sirs
Could I get advice for the following inquiries :
- Why does the safety factor for shear in columns is very high when I use only external stirrup ?
- Why does the safety factor for shear in column with internal stirrup is less than that of the column without internal stirrup ?
Please , Could you take a look for attached captures and file.
Note : If you use any capture for explanation . Kindly send it as attached.
Thanks in advance
Refaat
Please use plain text.
Product Support
Artur.Kosakowski
Re: factor of safety for shear in RC-Columns
12-27-2012 12:09 AM in reply to: refaat
I can't see such problem. Could you send me the file where you have the 'middle' stirrups defined?
Artur Kosakowski
refaat
12-27-2012 02:15 AM in reply to: Artur.Kosakowski
Dear Artur
Attached is the required file . could you take a look to it?
Thanks in advance
Refaat
Product Support
Artur.Kosakowski
12-27-2012 02:27 AM in reply to: refaat
What was the way you generated this reinforcement distribution in the column?
Artur Kosakowski
refaat
12-27-2012 04:00 AM in reply to: Artur.Kosakowski
Dear Artur
I used "Typical Reinforcement" option
Refaat
