Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
ezcessive number of load combination
3 REPLIES 3
stroxy
370 Views, 3 Replies
I have a model with 12 static load cases (tank with compartments). Now when I  add equivalent lateral force cases with definition of additional eccentricities in +/- X/Y directions, using Newmark combinations, I end up with 42 load cases.  Naturally yhis generates a huge number of combinations.  What would you advise in such a scenario to limit the number of combinations.  I have tried generating automatic simplified combinations (all bars) but it does not seem to help much.
3 REPLIES 3
Rafal.Gaweda
in reply to: stroxy
I am afraid you have to look at Relations and simplify them to generate smaller number of combinations.
Hint: use only seismic CQC combinations instead CQC + simple seismic cases or vice versa.
The limit can be changed here:
Rafal Gaweda
stroxy
in reply to: Rafal.Gaweda
I am still grappling with the groups and relations tabs in generating combinations.  For example I have unchecked the simplified seismic cases on the "cases" tab to make them inactive, but they still appear on the "Groups" and "Relations" tab
Rafal.Gaweda
in reply to: stroxy
OK, but they will not be used
Rafal Gaweda
