I have tried without noticeable success to write some code that could give me MAX and MIN bar forces values in several sections (for example spaced by 20cm) for a group of load cases or for a group of normal combinations (not code combinations) and write them down in Excel. In my model I have some vehicle type load cases so the code should work for them to.
Is it possible for you to provide me some code example on how to do this?
One good feature would be to detect the current bar selection on Robot View and extract those bars numbers and forces in several sections. Is it possible to do this?
Thank you
Adriano
Solved by Rafal.Gaweda. Go to Solution.
check files there:
result to excel
result> forces (reaction ... etc)>
in table - context menu (left mouse click) CONVERCION TO EXCEL (CSV) FORMAT
One remark: ValueEx works also for moving load cases so small modification in code to allow one to read such results
File attached.
