Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
extra loadings in view tab that are not in the loads tables
2 REPLIES 2
308 Views, 2 Replies
Good Morning/Afternoon!
I have in front of me a model which seems to show some added loading values in the view tab which do not appear anywhere in the loads table.
for example, when just displaying the selfweight loadcase (which should just display various UDL applied throughout the whole structure without any annotation)
several "uni.mass" components appear for each axis on each bar, causing quite a busy picture.
 I don't believe that this affects the results, however it is difficult to clearly see the loadcases and ultimately work with the model.
attached are a couple of screen captures.
Thank you, let me know if you need anything else
James
2 REPLIES 2
Artur.Kosakowski
When you convert load to mass do not select the global mass. Use dynamic or modal instead.
Artur Kosakowski
in reply to: Artur.Kosakowski
ah yeah, well spotted!  Thank you for the speedy response.
