Hi
In (CBSpro2013) ,Could I know if I have to inter the external pressure coeff. (Cp) (-0.50) as mentioned in the code (ASCE7-05) or leave it (0.50)?
Thanks ,
Refaat
Solved by Artur.Kosakowski. Go to Solution.
Hi
Pls , see the attached capture
Thanks ,
Refaat
Leave it as 0.5. This will produce loads acting in the same direction.
