Who has experience with exporting reinforced objects from RSA 2012 to ASD Reinforcement 2012?
I'm trying to export some objects, but get wrong or weird results.
Hi
2. Create and save several reinforcement patters and detail the selected beams with the same design option including among others selected main bar diameter as well as stirrup spacing
Please follow this link:
How the above design process be used for the file in the link. There are many beams, columns, panels, foundations,.. etc. Screencast please.
3. Calculating few most heavily loaded beams and make estimation of what reinforcement pattern will be needed, create it using the typical reinforcement option, save it and then use it for selected number of similar beams. After 'inserting' reinforcement to the beams you just run their verifications to make sure they are OK.
4. Finaly you can just edit bar diameter after exporting beams to ASD.
Dear Mustafa,
I will ask you this weekend.
It is good to know that we have more people trying to work with ASD
Gustavo
