Hi all.
I is prolem.
I design slap RC, But why I not export Steel of robot to revit strucutre ??
Solved by Artur.Kosakowski. Go to Solution.
Please check:
Thank Artur.
But I don't kwon Artut write : " On the other hand you can export it to ASD Reinforcement and generated dwg drawings there which you can link with the Revit model."
I do not Export ASD Reinforcement to Revit Modol???
It is not possible to directly export reinforcement of slab generated in Robot to Revit but you may find the following solution helpful:
1. Generate slab reinforcement drawing in Robot
2. Open this drawing in ASD reinforcement and save it as dwg
3. Link this dwg file with the project in Revit
Thank you.
But I do not use steel of revit structure.?????
Please see video.
http://www.screencast.com/t/ZBMO8OtzQZh
Thank again.
As you linked the 2D dwg drawing you will not be able to generate a cross section using Revit tool that is intended for a 3D model. The cross section view should be created in ASD and saved in the same or as a separate dwg file (that you link to Revit).
