Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Export results ARSA via API
74 REPLIES 74
Message 1 of 75
6331 Views, 74 Replies
I would like to export the results of efforts with VBA in excel files like in the video attached.
Can you help me ?
Export result
74 REPLIES 74
Message 21 of 75
Rafal.Gaweda
First remark - something is wrong with cases loop if you have more than 1 case selected.
Rafal Gaweda
Message 22 of 75
Rafal.Gaweda
Take a look at green code below.
This sub should work fine.
Sub extraction_resultats_cas()
Range("A13", "F25000").Clear
Range("B5").Clear
Set RobApp = New RobotApplication
If Not RobApp.Visible Then
Set RobApp = Nothing
MsgBox "Open Robot and load Model", vbOKOnly, "ERROR"
Exit Sub
Else
' If (RobApp.Project.Type <> I_PT_FRAME_3D) And (RobApp.Project.Type <> I_PT_SHELL) Then
' MsgBox "Structure Type should be FRAME 3D or SHELL", vbOKOnly, "ERROR"
' Exit Sub
' End If
Cells(5, 1) = "Project"
Cells(5, 2) = RobApp.Project.Name
'selection des barres
'If CheckBox1 = True Then
'Dim BarCol As RobotBarCollection
'Set BarCol = RobApp.Project.Structure.Bars.GetAll
'Else
Dim RSelection As RobotSelection
Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_BAR)
Set BarCol = RobApp.Project.Structure.Bars.GetMany(RSelection)
Dim num_bar As String
' If (BarCol.Count = 0) Then c'est un test de selection du modele
' If (MsgBox("No bars selected in Robot. Do you want to import results for all bars?", vbYesNo, "Warning") = vbYes) Then
num_bar = Cells(8, 2)
If num_bar = "" Then
If (MsgBox("Pas de numéro de barres indiqué ! Voulez-vous selectionner toutes les barres?", vbYesNo, "Warning") = vbYes) Then
RSelection.FromText "all"
RSelection.AddText "tous"
Else
Set BarCol = Nothing
Exit Sub
' ajout condition pour rentrer soi-meme les numéros de barres
Else
RSelection.FromText num_bar
'End If
Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_CASE)
Dim CaseCol As RobotCaseCollection
Set CaseCol = RobApp.Project.Structure.Cases.GetMany(RSelection)
Dim num_cas As String
num_cas = Cells(9, 2)
' If (CaseCol.Count = 0) Then
If num_cas = "" Then
If (MsgBox("Pas de cas ou combinaisons indiqué ! Voulez-vous importer les résultats de tous les cas ?", vbYesNo, "Warning") = vbYes) Then
Else
Set CaseCol = Nothing
Exit Sub
Else
RSelection.FromText num_cas
Cells(9, 2) = RSelection.ToText
NumberOfPoints = Int(Cells(10, 2).Value)
If (NumberOfPoints < 2) Then
MsgBox "Number of points along the bar must be greater or equal to 2", vbOKOnly, "Error"
Exit Sub
'Sleep 10000
Row = 12
' Cells(Row, 1) = "Barre"
' Cells(Row, 2) = "Noeud"
' Cells(Row, 3) = "Cas (/ Composante)"
' Cells(Row, 4) = "FX [kN]"
' Cells(Row, 5) = "FZ [kN]"
' Cells(Row, 6) = "MY [kN.m]"
Cells(19, 9) = "Progression"
For i = 1 To BarCol.Count
Cells(20, 9) = Str(i) + " / " + Str(BarCol.Count)
Dim RBar As RobotBar
Set RBar = BarCol.Get(i)
BarNumber = RBar.Number
BarStr = Str(BarNumber)
OriNodeStr = Str(RBar.StartNode)
EndNodeStr = Str(RBar.EndNode)
Dim BFD As RobotBarForceData
Dim Icomp As Integer
Dim BarForceServer As RobotBarForceServer
Set BarForceServer = RobApp.Project.Structure.Results.Bars.Forces
Dim Point As Double
Dim Step As Double
Point = 0#
Step = 1# / (NumberOfPoints - 1)
For ii = 1 To NumberOfPoints
For j = 1 To CaseCol.Count
AT = CaseCol.Get(j).AnalizeType
If AT <> I_CAT_COMB_CODE _
And AT <> I_CAT_COMB _
And AT <> I_CAT_COMB_NONLINEAR _
And AT <> I_CAT_STATIC_LINEAR _
And AT <> I_CAT_STATIC_NONLINEAR Then
MsgBox "This macro works only for simple load cases, combinations and automatic combinations", vbOKOnly, "Error"
Exit Sub
UNC = CaseCol.Get(j).Number
CaseStr = Str(UNC)
If CaseCol.Get(j).Type = I_CT_CODE_COMBINATION Then ' pour les combinaisons
Dim CCount As Integer
CCount = CaseCol.Get(j).Components.Count
Dim StrCC As String
StrCC = Str(CCount)
If InStr(CaseCol.Get(j).Name, "+") <> 4 And InStr(CaseCol.Get(j).Name, "-") <> 4 And InStr(CaseCol.Get(j).Name, "+") <> 8 And InStr(CaseCol.Get(j).Name, "-") <> 8 Then
For Icomp = 1 To CCount
CompStr = " / " + Str(Icomp)
Row = Row + 1
If ii = 1 Then
Cells(Row, 1) = BarStr
Cells(Row, 2) = OriNodeStr
Cells(Row, 3) = CaseStr + CompStr
ElseIf ii = NumberOfPoints Then
Cells(Row, 2) = EndNodeStr
Else
Cells(Row, 1) = BarStr + Str(ii) + " /" + Str(NumberOfPoints) + " / " + CaseStr + CompStr
Set BFD = BarForceServer.ValueEx(BarNumber, UNC, Icomp, Point)
Cells(Row, 4) = BFD.FX * 0.001
Cells(Row, 5) = BFD.FZ * 0.001
Cells(Row, 6) = BFD.MY * 0.001
Set BFD = Nothing
Next Icomp
Else ' pour les cas simples
Row = Row + 1
If ii = 1 Then
Else
Cells(Row, 2) = Str(ii) + " /" + Str(NumberOfPoints)
Set BFD = BarForceServer.Value(BarNumber, UNC, Point)
Set BFD = Nothing
Next j
Point = Point + Step
Next ii
Next i
Cells(19, 9) = ""
Cells(20, 9) = ""
End Sub
Rafal Gaweda
Message 23 of 75
in reply to: Rafal.Gaweda
ok thanks, do you know how to change with API the scale of results on graphic ?
scale
Message 24 of 75
Bonjour,
Do you know how to export the reactions kz like :
Cells(Row, 7) = BFD.KZ * 0.001
réaction Kz
Message 25 of 75
Rafal.Gaweda
I am afraid it is not possible to control scale by API.
Rafal Gaweda
Message 26 of 75
Rafal.Gaweda
mateaus
This is KZ value , the one to the left from Reaction KZ checkbox shown on your screen capture
réaction Kz
Raction KZ is not available thru API. You have to calculate it by yourself \ your code.
Example below - additional code in green.
Keep in mind that results strongly depend on number of points along bar and compaxity of KZ diagram.
Dim KZReaction() As Double
ReDim KZReaction(2)
KZReaction(1) = 0#
Dim EleLen As Double
EleLen = 0#
Dim KZAComb As Boolean
Dim KZACode As Boolean
KZACode = False
KZAComb = False
ReDim KZReaction(CCount)
For iicomp = 1 To CCount
KZReaction(iicomp) = 0#
Next iicomp
Dim StrCC As String
StrCC = Str(CCount)
CompStr = "/" + Right(Str(Icomp), Len(Str(Icomp)) - 1)
Row = Row + 1
If ii = 1 Then
Cells(Row, 1) = barstr + OriNodeStr + CaseStr + CompStr
Cells(Row, 1) = barstr + EndNodeStr + CaseStr + CompStr
Else
Cells(Row, 1) = barstr + Str(ii) + "/" + Right(Str(NumberOfPoints), Len(Str(NumberOfPoints)) - 1) + " / " + CaseStr + CompStr
Cells(Row, 2) = BFD.FX
Cells(Row, 3) = BFD.FZ
Cells(Row, 4) = BFD.MY
' Cells(Row, 5) = BFD.KZ
KZACode = BFD.KZAvailable
If KZACode Then
EleLen = RBar.Length / (NumberOfPoints - 1)
If ii = 1 Or ii = NumberOfPoints Then EleLen = EleLen / 2
' Cells(Row, 6) = BFD.KZ * EleLen
KZReaction(Icomp) = KZReaction(Icomp) + BFD.KZ * EleLen
Set BFD = Nothing
Next Icomp
Else
Row = Row + 1
If ii = 1 Then
Else
KZAComb = BFD.KZAvailable
If KZAComb Then
KZReaction(1) = KZReaction(1) + BFD.KZ * EleLen
Set BFD = Nothing
Next ii
If KZAComb Then
Cells(Row, 7) = "KZ Reaction for bar " & Str(BarNumber) & " Case " & CaseStr
Cells(Row, 😎 = KZReaction(1)
KZAComb = False
If KZACode Then
Cells(Row - CCount + Icomp, 7) = "KZ Reaction for bar " & Str(BarNumber) & " Case " & CaseStr & " /" & Str(Icomp)
Cells(Row - CCount + Icomp, 😎 = KZReaction(Icomp)
KZACode = False
Next Icomp
Next j
Next i
Cells(20, 😎 = ""
Cells(20, 9) = ""
End Sub
Rafal Gaweda
Message 27 of 75
I would like to export results of my plate with VBA.
Now I'm doing this :
Can you give the macro to export it in excel automatically for simple case and moving case (only composant LM2 + LM2 _ ...) together ?
Message 28 of 75
Rafal.Gaweda
Take a look at attached xls
Rafal Gaweda
Message 29 of 75
Ok good but I'm looking for results by nodes.
Have good something for me ?
Message 30 of 75
Rafal.Gaweda
Example attached
Rafal Gaweda
Message 31 of 75
is it possible to have a table of resultant loads like that :
Thank you for your answer.
Message 32 of 75
Is that possible to export results of a cut of a slab in a table :
Message 33 of 75
To export results of panel, I would like to select only a list of finit elements (nodes).
Is that possible you modify your file ?
For the results I prefer to export the average in each node like this :
Thank you for you answer.
Message 34 of 75
Rafal.Gaweda
I do not knwo what is the centre de poussee and how it is calculated so you can take
RobApp.Project.Structure.Results.Nodes.Reactions.DDC*
or
RobApp.Project.Structure.Results.Nodes.Reactions.Sum*
to get Forces \ Moments Resultatntes then calculate  centre de poussee in your macro.
Rafal Gaweda
Message 35 of 75
Rafal.Gaweda
I think:
either: generate view I_VT_DETAILED_ANALYSIS, generate panel cut and make screen capture of this view
or
get reduced results from panel
RobApp.Project.Structure.Results.FiniteElems.Reduced.*
Rafal Gaweda
Message 36 of 75
Rafal.Gaweda
File Attached.
Rafal Gaweda
Message 37 of 75
File Attached.
Ok for the option of results but I would like to ask for a list of nodes and not all of them.
I your file you have to select in the model before. I would like to ask in cases of excel file for results of a chosen list of elements (nodes of a panel) and cases.
Can you modify your macro for it ?
Message 38 of 75
Rafal.Gaweda
 for selection of fes and nodes attached
Rafal Gaweda
Message 39 of 75
Hi it doesn't work I think. Can we enter a list of nodes in a excel cell and have the results of the selection ?
Message 40 of 75
Rafal.Gaweda
No it works on nodes selection and FEs selection made in Robot
Rafal Gaweda
