Export results ARSA via API
74 REPLIES 74
Message 1 of 75
6334 Views, 74 Replies
I would like to export the results of efforts with VBA in excel files like in the video attached.
Can you help me ?
Export result
74 REPLIES 74
Message 41 of 75
in reply to: Rafal.Gaweda
@Anonymous_Adsk wrote:
for selection of fes and nodes attached
Hi it doesn't work I think. Can we enter a list of nodes in a excel cell and have the results of the selection ?
No it works on nodes selection and FEs selection made in Robot
I tried to modify the macro to be able to enter the number of selection in cell(9.2) but it doesn't work.
My goal is not have to interact with the model.
Only pilot in excell :
        Dim obj As RobotObjObject
        Dim FECollection As RobotFiniteElementCollection
        Dim FEs As String
        Dim NodesSel As String
        Dim NodeSelection As RobotSelection
        Dim NodeCollection As RobotNodeCollection
        Set RSelection = RobApp.Project.Structure.Selections.Create(I_OT_FINITE_ELEMENT)
        Set NodesSelection = RobApp.Project.Structure.Selections.Create(I_OT_NODE)
        RSelection.FromText ""
        NodesSelection.FromText " "
        For jj = 1 To PanelCol.Count
            Set obj = RobApp.Project.Structure.Objects.Get(PanelCol.Get(jj).Number)
            FEs = obj.FiniteElems
            NodeSel = obj.Nodes
            RSelection.AddText (FEs)
            NodesSelection.AddText (NodeSel)
        Next jj
        If (OptionButton1.Value) Then
            Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_FINITE_ELEMENT)
            If (RSelection.Count = 0) Then
                MsgBox "FEs not selected", vbOKOnly, "ERROR"
                RobApp.Interactive = True
            Exit Sub
            End If
        End If
        If (OptionButton2.Value) Then
            Set NodesSelection = RobApp.Project.Structure.Selections.Get(I_OT_NODE)
            num_node = Cells(9, 2)
            If num_node <> "" Then
                NodesSelection.FromText num_node
                Set NodesSelection = RobApp.Project.Structure.Nodes.GetMany(NodesSelection)
            Else
                If (NodesSelection.Count = 0) Then
                    MsgBox "Nodes not selected", vbOKOnly, "ERROR"
                    Set NodesSelection = Nothing
                    Exit Sub
                End If
            End If
        End If
        Set FECollection = RobApp.Project.Structure.FiniteElems.GetMany(RSelection)
        Set NodeCollection = RobApp.Project.Structure.Nodes.GetMany(NodesSelection)
 I just want to choose nodes and cases in excell.
Can you modify the macro for it ?
Message 42 of 75
rsousa_
I don't know if i understand correctly what you want, but see if this can help you. You have to put your selection set only in excel... Test the sheet, because i had little time to program the exceptions...
Regards
Message 43 of 75
Every time I get the same error "Select case(s), combinations(s) in robot.
What I have to do? I put case in B10 cell but still doesn0t work
Message 44 of 75
hi @Rafal.Gaweda I say you macro "panel_res", but I do not get the same results as in ARSA. In particular in ARSA I get Max moment around 12 kNm/m while in your macro 8.2 kNm/m. Maybe through your macro I obtain different values. If yes, how can I get the value through macro of Maps-Detailed-Moment please?
Thanks Rafal
Message 45 of 75
Rafal.Gaweda
Hi @Anonymous
Macro gives you exactly the same values like in Robot
Rafal Gaweda
Message 46 of 75
thanks @Rafal.Gaweda for replying,
How can I get the Moment Value 12.78 kNm/m that appears in the Result-Maps?
Because I did by hand the calculation and the result should be around that number.
Message 47 of 75
Rafal.Gaweda
Hi @Anonymous
You need to modify macro to get Myy results
Rafal Gaweda
Message 48 of 75
@Rafal.Gaweda I kindly ask you if you could add here the strings to add that code.
Can you send me the link where is written the difference between the Fe complex value and the Fe principal value please?
Message 49 of 75
Rafal.Gaweda
Hi @Anonymous
This way:
Rafal Gaweda
Message 50 of 75
Hi @Rafal.Gaweda could you please post here a screen or a video about to import results if I select: Load Case Code Combinations - Full automatic combinations, please?
Because I do not get results if I select that code combinations
Message 51 of 75
Rafal.Gaweda
Hi @Anonymous
This macro does not work for Code Combinations.
You have to add some code to it doing that.
Rafal Gaweda
Message 52 of 75
@Rafal.Gaweda Can you kindly put some piece of that code please?
Message 53 of 75
Rafal.Gaweda
Hi @Anonymous
Here you are
            ElseIf (RCaseCol.Get(ii).Type = I_CT_CODE_COMBINATION) Then
                Dim CCount As Integer
                Dim CCa As RobotCodeCombination
                Set CCa = RCaseCol.Get(ii)
                CCount = CCa.Components.Count
                Dim StrCC As String
                StrCC = Str(CCount)
                If InStr(RCaseCol.Get(ii).Name, "+") <> 4 And InStr(RCaseCol.Get(ii).Name, "-") <> 4 And InStr(RCaseCol.Get(ii).Name, "+") <> 8 And InStr(RCaseCol.Get(ii).Name, "-") <> 8 Then
                    FEparams.Case = CCa.Number
                    For icomp = 1 To CCount
                        row = row + 1
                        FEparams.CaseCmpnt = icomp
                    If (OptionButton1.Value) Then Cells(row, 1) = Str(FEparams.Element) + " / " + Str(FEparams.Case) + " / " + Str(FEparams.CaseCmpnt)
                    If (OptionButton2.Value) Then Cells(row, 1) = Str(FEparams.Node) + " / " + Str(FEparams.Case) + " / " + Str(FEparams.CaseCmpnt)
                    If (OptionButton3.Value) Then Cells(row, 1) = Str(FEparams.Panel) + " / " + Str(FEparams.Node) + " / " + Str(FEparams.Case) + " / " + Str(FEparams.CaseCmpnt)
                    Set FEresults = RobApp.Project.Structure.Results.FiniteElems.Detailed(FEparams)
                    Cells(row, 2) = FEresults.QXX
                    Cells(row, 3) = FEresults.QYY
                    Set FEcomplex = RobApp.Project.Structure.Results.FiniteElems.Complex(FEparams)
                    Cells(row, 4) = FEcomplex.MXX_TOP
                    Cells(row, 5) = FEcomplex.MXX_BOTTOM
                    Cells(row, 6) = FEcomplex.MYY_TOP
                    Cells(row, 7) = FEcomplex.MYY_BOTTOM
                    Next icomp
                End If
Rafal Gaweda
Message 54 of 75
@Rafal.Gaweda the units are daNm/m?  Because I'm getting confuse with this macro about the units! Can you specify them please?
Message 55 of 75
Rafal.Gaweda
Hi @Anonymous
SI units (N, m, Nm...).
All data set \ get \ stored in Robot by API should be in SI units. If you want different units you need to multiply results in code by your own.
Rafal Gaweda
Message 56 of 75
@Rafal.Gaweda Does not matter if I have daNm/m in my Results-Maps?
Just to confirm: Membrane forces [N]
Moment [Nm/m]
Shear forces [N/m]
Correct?
Message 57 of 75
Rafal.Gaweda
Hi @Anonymous
All data set \ get \ stored in Robot by API should be \ is in SI units. If you want different units you need to multiply results in code by your own.
Rafal Gaweda
Message 58 of 75
Hi @Rafal.Gaweda
I would share with you my problem with your macro! It is awesome and I use it almost everyday!
I'm designing a classic pool, for Walls 7 and 9 everything is perfect  but I get 0 values for the wall 8 and 10. Could you check the reason please?
Message 59 of 75
Rafal.Gaweda
Hi @Anonymous
You need to adjust results direction settings.
It is defined
FEparams.SetDirX I_OLXDDT_CARTESIAN, 1, 0, 0
For walls along Y it should be
FEparams.SetDirX I_OLXDDT_CARTESIAN, 0, 1, 0
Rafal Gaweda
Message 60 of 75
@Rafal.Gaweda I have changed the code
in
but I still get 0 values.
In any case, Do I have to change every time the code depending if I'm exporting values from X directions or Y directions?
