I would like to export the results of efforts with VBA in excel files like in the video attached.
Can you help me ?
Solved by rsousa_. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
Thanks.
Not possible to save csv from table by API. So you have to import these results to Excel then save xls file(s).
Ok, but is there a way to export results by API ?
Yes, of course.
I will write you sample code.
Could you send me an example to have list of efforts (Fx Fz My) with API VBA ?
xls file with example of table with internal forces attached.
Ok thank you,
I try it and it works but we have to select the bars before in the model. I will search by myself how to make it automaticaly and if I don't succeed I'll ask you one more time.
Just an Question. It's slow, do I need a lot of RAM to turn it faster ?
My System :
Windows XP Professionnel 2002 SP3
Intel(R) Xeon(R) CPU
W3505 @ 2.53GHz
2.53 GHz, 2.99 Go de RAM
Carte Graphique :
NVIDIA Quadro FX 580
What do you mean by that ?
No, it does not depend on RAM.
I will check the code to accelerate it - if possible.
To select automatically all the bars.
If you do not select any bar it will ask you whether to select ALL of them or stop macro.
or replace this section :
Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_BAR)
Dim BarCol As RobotBarCollection
Set BarCol = RobApp.Project.Structure.Bars.GetMany(RSelection)
If (BarCol.Count = 0) Then
If (MsgBox("No bars selected in Robot. Do you want to import results for all bars?", vbYesNo, "Warning") = vbOK) Then
RSelection.FromText "all"
RSelection.AddText "tous"
Else
Set BarCol = Nothing
Exit Sub
End If
End If
by
Set BarCol = RobApp.Project.Structure.Bars.GetAll
I am attaching updated macro.
- Faster
- You may specify number of points along bar in it (2 as a default for begining and end only)
Ok but I don't know why but if I select a bar it give me the result of the bar selected before and I have to demand a second time to have the good results for the bars selected.
Small correction in attached file.
It may happen that somehow the selection in "not confirmed" in Robot. Try to activate Bar selection filed (combo) on top of Robot on Selection toolbar (click inside it) then "confirm selection" by pressing Enter or Tab.
Ok but my goal at the end is not to have to manipulate the program Robot and only use the macro VBA in excel. Is there another solution ?
Do you mean, for example, writing selection fo bar(s) , case(s) in Excell and not to use selection from Robot? There is no problem with it. Please write down what is the workflow in your mind.
I have already modify the macro to demand bar(s) , case(s) in Excell. But I have to run the macro twice to have the good selection. I would like to do it in one time without using Robot.
My macro where the selections are read from xls file attached.
Hi, I've modified the macro to have results with an other order :
1 - Number bar
2 - Number node
2 - Cases
For example
1 / 1 / 101 Fx Fz My
1 / 1 / 102 Fx Fz My
1 / 2 / 101 Fx Fz My
1 / 2 / 102 Fx Fz My
But it's not exporting the good efforts
Would you mind correct it ?
Sub extraction_resultats_cas() Range("A13", "F25000").Clear Range("B5").Clear Set RobApp = New RobotApplication If Not RobApp.Visible Then Set RobApp = Nothing MsgBox "Open Robot and load Model", vbOKOnly, "ERROR" Exit Sub Else If (RobApp.Project.Type <> I_PT_FRAME_3D) And (RobApp.Project.Type <> I_PT_SHELL) Then MsgBox "Structure Type should be FRAME 3D or SHELL", vbOKOnly, "ERROR" Exit Sub End If Cells(5, 1) = "Project" Cells(5, 2) = RobApp.Project.Name 'selection des barres 'If CheckBox1 = True Then 'Dim BarCol As RobotBarCollection 'Set BarCol = RobApp.Project.Structure.Bars.GetAll 'Else Dim RSelection As RobotSelection Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_BAR) Dim BarCol As RobotBarCollection Set BarCol = RobApp.Project.Structure.Bars.GetMany(RSelection) Dim num_bar As String ' If (BarCol.Count = 0) Then c'est un test de selection du modele ' If (MsgBox("No bars selected in Robot. Do you want to import results for all bars?", vbYesNo, "Warning") = vbYes) Then num_bar = Cells(8, 2) If num_bar = "" Then If (MsgBox("Pas de numéro de barres indiqué ! Voulez-vous selectionner toutes les barres?", vbYesNo, "Warning") = vbYes) Then RSelection.FromText "all" RSelection.AddText "tous" Set BarCol = RobApp.Project.Structure.Bars.GetMany(RSelection) Else Set BarCol = Nothing Exit Sub End If ' ajout condition pour rentrer soi-même les numéros de barres Else RSelection.FromText num_bar Set BarCol = RobApp.Project.Structure.Bars.GetMany(RSelection) End If 'End If Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_CASE) Dim CaseCol As RobotCaseCollection Set CaseCol = RobApp.Project.Structure.Cases.GetMany(RSelection) Dim num_cas As String num_cas = Cells(9, 2) ' If (CaseCol.Count = 0) Then If num_cas = "" Then If (MsgBox("Pas de cas ou combinaisons indiqué ! Voulez-vous importer les résultats de tous les cas ?", vbYesNo, "Warning") = vbYes) Then RSelection.FromText "all" RSelection.AddText "tous" Set CaseCol = RobApp.Project.Structure.Cases.GetMany(RSelection) Else Set CaseCol = Nothing Exit Sub End If Else RSelection.FromText num_cas Set CaseCol = RobApp.Project.Structure.Cases.GetMany(RSelection) End If Cells(9, 2) = RSelection.ToText NumberOfPoints = Int(Cells(10, 2).Value) If (NumberOfPoints < 2) Then MsgBox "Number of points along the bar must be greater or equal to 2", vbOKOnly, "Error" Exit Sub End If 'Sleep 10000 Row = 12 ' Cells(Row, 1) = "Barre" ' Cells(Row, 2) = "Noeud" ' Cells(Row, 3) = "Cas (/ Composante)" ' ' Cells(Row, 4) = "FX [kN]" ' Cells(Row, 5) = "FZ [kN]" ' Cells(Row, 6) = "MY [kN.m]" Cells(19, 9) = "Progression" For i = 1 To BarCol.Count Cells(20, 9) = Str(i) + " / " + Str(BarCol.Count) Dim RBar As RobotBar Set RBar = BarCol.Get(i) BarNumber = RBar.Number BarStr = Str(BarNumber) OriNodeStr = Str(RBar.StartNode) EndNodeStr = Str(RBar.EndNode) Dim BFD As RobotBarForceData Dim Icomp As Integer Dim BarForceServer As RobotBarForceServer Set BarForceServer = RobApp.Project.Structure.Results.Bars.Forces Dim Point As Double Dim Step As Double Point = 0# Step = 1# / (NumberOfPoints - 1) For ii = 1 To NumberOfPoints For j = 1 To CaseCol.Count AT = CaseCol.Get(j).AnalizeType If AT <> I_CAT_COMB_CODE _ And AT <> I_CAT_COMB _ And AT <> I_CAT_COMB_NONLINEAR _ And AT <> I_CAT_STATIC_LINEAR _ And AT <> I_CAT_STATIC_NONLINEAR Then MsgBox "This macro works only for simple load cases, combinations and automatic combinations", vbOKOnly, "Error" Exit Sub End If UNC = CaseCol.Get(j).Number CaseStr = Str(UNC) If CaseCol.Get(j).Type = I_CT_CODE_COMBINATION Then ' pour les combinaisons Dim CCount As Integer CCount = CaseCol.Get(j).Components.Count Dim StrCC As String StrCC = Str(CCount) If InStr(CaseCol.Get(j).Name, "+") <> 4 And InStr(CaseCol.Get(j).Name, "-") <> 4 And InStr(CaseCol.Get(j).Name, "+") <> 8 And InStr(CaseCol.Get(j).Name, "-") <> 8 Then For Icomp = 1 To CCount CompStr = " / " + Str(Icomp) Row = Row + 1 If ii = 1 Then Cells(Row, 1) = BarStr Cells(Row, 2) = OriNodeStr Cells(Row, 3) = CaseStr + CompStr ElseIf ii = NumberOfPoints Then Cells(Row, 1) = BarStr Cells(Row, 2) = EndNodeStr Cells(Row, 3) = CaseStr + CompStr Else Cells(Row, 1) = BarStr + Str(ii) + " /" + Str(NumberOfPoints) + " / " + CaseStr + CompStr End If Set BFD = BarForceServer.ValueEx(BarNumber, UNC, Icomp, Point) Cells(Row, 4) = BFD.FX * 0.001 Cells(Row, 5) = BFD.FZ * 0.001 Cells(Row, 6) = BFD.MY * 0.001 Set BFD = Nothing Next Icomp End If Else ' pour les cas simples Row = Row + 1 If ii = 1 Then Cells(Row, 1) = BarStr Cells(Row, 2) = OriNodeStr Cells(Row, 3) = CaseStr ElseIf ii = NumberOfPoints Then Cells(Row, 1) = BarStr Cells(Row, 2) = EndNodeStr Cells(Row, 3) = CaseStr Else Cells(Row, 1) = BarStr Cells(Row, 2) = Str(ii) + " /" + Str(NumberOfPoints) Cells(Row, 3) = CaseStr End If Set BFD = BarForceServer.Value(BarNumber, UNC, Point) Cells(Row, 4) = BFD.FX * 0.001 Cells(Row, 5) = BFD.FZ * 0.001 Cells(Row, 6) = BFD.MY * 0.001 Set BFD = Nothing End If Point = Point + Step Next j Next ii Next i End If Cells(19, 9) = "" Cells(20, 9) = "" End Sub
