Hi
I want to be able to export required reinfocement maps with description to either dwg or dxf. I have tried 'save as' dxf, but I only get extreme values exportet, while I am interested in exporting more values (i.e. for finite element centers).
Is there any settings to how this view is exported and how can I do this?
Furthermore, I am interested displaying result for a supplier which do not have the software. Is there any other way of doing this?
I have tried screen shoots and printout composition choosing papersize A0, but the text becomes unreadable.
Any guidence here would be much appriciated.
Kind regards
You may consider display of isolines instead with values of the scale entered as area of reinforcement (e.g. assuming that you want to use 20 mm rebars you can have the values on the scale equal to area of fi20 @ 5 cm; fi20 @ 10 cm; fi 20 @ 15 cm etc.
Implemented in RSA 2017.
